Apache2 wont start for ns1
Sorry if my info is skewed.
I have been having trouble with importing servers from Backblaze, since doing tar.gzip archives.
Then found out just to do the default archive.
I had errors since trying to upgrade my system to Debian 13, and then my server was useless.
I have now got a stable Linux installed and just got the pro version of Virtualmin installed.
Got my servers installed and now running a problem with apache2 as it just does not want to start nor can start the service.
Please help.
Run this in the terminal and tell us what it reports.
systemctl start apache2
× apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Thu 2025-09-25 22:58:38 BST; 27s ago
Docs: Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Process: 661252 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
CPU: 22ms
Sep 25 22:58:38 ns1.baillat.uk systemd[1]: Starting apache2.service - The Apache HTTP Server…
Sep 25 22:58:38 ns1.baillat.uk apachectl[661255]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:443
Sep 25 22:58:38 ns1.baillat.uk apachectl[661255]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:443
Sep 25 22:58:38 ns1.baillat.uk apachectl[661255]: no listening sockets available, shutting down
Sep 25 22:58:38 ns1.baillat.uk apachectl[661255]: AH00015: Unable to open logs
Sep 25 22:58:38 ns1.baillat.uk apachectl[661252]: Action ‘start’ failed.
Sep 25 22:58:38 ns1.baillat.uk apachectl[661252]: The Apache error log may have more information.
Sep 25 22:58:38 ns1.baillat.uk systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Sep 25 22:58:38 ns1.baillat.uk systemd[1]: apache2.service: Failed with result ‘exit-code’.
Do you have another web server or possibly a docker container running?
netstat -ap |grep 443
no just the main server.
Run sudo lsof -nP -iTCP:443 -sTCP:LISTEN and check if another process/server is listening on port 443.
If you see another server, stop it.
Or Apache itself is trying to bind 443 twice…
Ah, alright. Sadly this is a known issue.
Do the following:
  1. Type the following in the Virtualmin search bar and press enter:
    !edit /etc/apache2/ports.conf
  2. Make sure that the file contents is as follows:
    # If you just change the port or add more ports here, you will likely also
    # have to change the VirtualHost statement in
    # /etc/apache2/sites-enabled/000-default.conf
    Listen 80
    <IfModule ssl_module>
    	Listen 443
    </IfModule>
    <IfModule mod_gnutls.c>
    	Listen 443
    </IfModule>
    • Save the file and close the panel
  3. Then try restarting Apache from Terminal module again.
tried that @Steini no other 443
that fixed the issue thanks for your help/
Great!
Can you please tell me more about your cloud provider and how you installed Virtualmin? Is this a clean install?
