Apache webserver is not starting
Webmin version 2.101
Usermin version 2.001
Virtualmin version 7.8.2
Theme version 21.04
Getting this error
Authentication failure
Nov
12
13:00:22
vmi1085163.
saslauthd 5231:
: auth failure: [user=] [service=smtp]
Smtp is a mail service not a web service. You do better to look at the apache logs to see what is going wrong with the webserver.
@hsnmalik,
What does the following command return:
sudo systemctl --no-pager status apache2
Try to disable SASL services, everything seem work well after did that.
smtp (pop3, imap maybe as well) authentication will fail if you do that. What is working well?
