Apache server not starting after setting timeserver from webmin
I set up time server sync from webin panel https://doxfer.webmin.com/Webmin/System_Time
It gaev error that ntp is not installed. after installing ntp via apt-get, time server sync worked but apache and ftp server not starting anymore.
what can be the problem?
Check the log files. Without details, there is not much someone can do.
You can try to start apache on the cmd line. It will show the error. I’m betting its something to do with timezone in apache vs timezone of the OS.
thank you guys for your replies, I reinstalled Virtualmin and restored the domains using the backup.
Although I was a bit scared to change the timezone on Webmin but everything seems to work well for now.
