The ondemand governor may already be in your php-fpm build…
Here is the best information I have found…
https://bugs.php.net/bug.php?id=52569
Hey Virtualmin folks - if you need an example of setting up PHP-FPM programmatically, check out TuxLite. It uses PHP-FPM exclusively. Maybe it will give you some inspiration.
(And if Virtualmin started supporting PHP-FPM and I missed it, let me know. That’d rock.)
Any update on PHP-FPM support in Virtualmin, Eric? I don’t want to sound harsh but it’s been a long time since you were reviewing it, does this mean you’re not going to add it?
Patrick
Unfortunately, for the time being, that’s something that would need to be manually configured. Jamie doesn’t have plans to add Virtualmin support for that in the near future.
Ok, thanks for letting me know!
Patrick
