Hi all, I have an issue i cannot get my head arround. I cannot be the only person using Virtualmin with this issue?
When my Dynamic IP updates, virtualmin adds the new ip to the first domain in the apache conf file but leaves the old IP in place. It does not change my second Domains to the new IP.
Consiquently when i restart apache i get the following error
Starting httpd: httpd: Syntax error on line 987 of /etc/httpd/conf/httpd.conf: /etc/httpd/conf/httpd.conf:987: was not closed.
[FAILED]
I have to manually remove the dead IP from httpd.conf in order for the service to start backup.
Also DNS updates the full Domain on the first created Domain but, only the first record of the second created Domain.
All the Domains use the standard shared IP in the Domain configs.
Strange i know but thats the way it is - and i have rebuilt the box thinking it was something i had changed that was causing the problem
Someone please shead a little light on the situation.
Fallen
