Hi there!
How to force Apache to read contents only from /home/domainname.tld/public_html/ and not contents from /var/www/html?
Server info:
OS: CentOS Linux 7 x86_64
Virtualmin: latest version
Webmin: latest version
Web Server: Apache 2.4.6
Hi there!
Server info:
I think you can select the default directory for the host in Virtualmin tab, select the preferred virtual domain and go to “Server Configuration/Website Options” and select YES in option “Default website for IP address?”, I that will do it!
Regards,
Leffe
Hi again,
I just remembered that there also is a setting in “Webmin/Servers/Apache Webserver” select “Default Server” in tab “Existing Virtual Hosts”, and in “Document Options” there is a selection for the “Document root directory”… maybe this was what you where looking for.
Regards,
Leffe
Would be fine if I change from /var/www/html to /home?
I think you need to enter the whole path to the virtual domain, like you wroth in #1
...read contents only from /home/domainname.tld/public_html/
//Leffe
Helpful answer
