Nearly every web application has a login form. A method of gaining user input with a username and password (or an email address and a password) there are some other newer methods available. but all require some user input/token system. Blocking global access to the form makes no sense (the security is in the way the input data is handled eg password encryption and storage)
thank for answer
i tried to recover a unfinished customerĀ“ proyect from a dead friend designer. i recover the entire drupal proyect , but this web is protected with a login form (equal to htpassword) but in the VS there isnĀ“t protected folder, and if i trace for manually protected forder w/o success. in the past, when i restored VS from a backup, certain skill werent recover, o the flags of this skill showed disable, but it remained enabled. is there any chance of similar problem? ( i recover proyect from a VS backup). are there any way to create a HTTP auth in this VS . User name and password of this login are specific and diferent from Virtualmin or drupal set.
tx in advance
