After CM install system wont boot up with network configuration
Hi! I have a situation like this:
I have a ubuntu 14.04 LTS x64
I was installed virtualmin, webmin…
now i installed cloudmin and i see that:
This system cannot be a KVM host : No bridge interfaces like br0 were found
Virtual systems cannot be created or added until this is fixed.
I made restart and machine wotn boot up anymore with network config.
I check /etc/network/interfaces
and see this:
auto lo br0 eth0
iface lo inet loopback
iface eth0 inet manual
iface br0 inet static
adress 192.168.0.110
netmask 255.255.255.0
broadcast 192.168.255.255
network 192.168.0.0
gateway 192.168.0.1
bridge_ports eth0
and with it system boot up but without network
so i tryed this with my ip addresses etc:
auto eth0 lo br0
address 192.168.0.110
network 192.168.0.0
gateway 192.168.0.1
bridge_ports eth0
bridge_fd 9
bridge_hello 2
bridge_maxage 12
bridge_stp off
and still stuck:/
so i changed adapter setting back to:
auto lo eth0
iface eth0 inet static
network 192.168.0.0
gateway 192.168.0.1
and then it boot up with network again and i get this:
So whrere or what s wrong?
Something with bridge?
Thnx!
Ok that is ok now… it my bad:) forgot to do some things:)
but now i hawe stuck in here:
VNC has been configured on this system by Cloudmin, but the VNC server on port 5901 on host system ns1 is not accessible. If it was just enabled, the system will need to be rebooted before VNC is available.
Same problem here, what things did you forgot to do?
