Just to make sure and to get your advice. I installed a new server with Debian 11 using the beta installer, all seems to be ok so far.
Once the install is done and everything works what is your advice:
- wait for a final update of installer and reinstall both OS and Virtualmin
- wait for a final update of installer and just re-run installer (if that’s possible ?)
- doesn’t matter, if install was successful server can be used and virtualhosts started immediately, no need to reinstall OS nor Virtualmin because install script will never be re-used
This in fact it just points my own lacking knowledge, I thought that the installer ran once and then, once everything was installed the virtualmin-server took over as far as updates (and managing the server of course) were concerned … not re-installing would mean maybe discovering something missing 2 months from now and being forced to re-install everything from scratch to re-run the stable installer … ?
Thks.
Pierre
