So lets check again because you mention both “Futurenode” and “Futurehost”. Me When I go on skytower.futurehost.dk I get this joycefull list (no harms, I’m really having fun):
The certificate is only valid for the following names: admin.futurehost.dk, admin.futurenode.dk, admin.futurenode.net, admin.futurenode.org, admin.halfdaner.dk, autoconfig.futurenode.dk, autodiscover.futurenode.dk, futurehost.dk, futurenode.dk, futurenode.net, futurenode.org, halfdaner.dk, mail.futurenode.dk, webmail.futurehost.dk, webmail.futurenode.dk, webmail.futurenode.net, webmail.futurenode.org, webmail.halfdaner.dk, www.futurehost.dk, www.futurenode.dk, www.futurenode.net, www.futurenode.org, www.halfdaner.dk
So first 5 Domain for 1 platform can only lays to problems, especially if you are a beginner.
Then if you ask the redirection (:10000) to be done for skytower.futurehost.dk I think it’s normal that admin.futurehost.dk only redirect to futurehost.dk (and not :10000).
Still then you also mention http://admin.futurenode.org (.org and not .dk). This time it start to be kinda complex because there are probably so much redirection rules … I can hardly said.
But I would like to precise: Have several domain name for the same platform is not good for referencing and might even hidde your platforms from search result (Or at least decrease its rank).
But if you need it, you litteraly need a ssl certificate for every single domain and subdomains AND redirect rules setup for each (Let say it depend your setup but I guess today it have to be a mess
The best would be to recreate the first alias (if futurenode.dk
was the main domain I suppose the first alias is futurehost.dk
) and only then, when everything work (Redirection AND ssl), you add a second alias (which might be futurenode.org
But again Usually 1 Domain is enough and you will get a better referencing on Search Engine.
