I’ve been testing Virtualmin Pro and the reseller feature on Ubuntu 20.04 and it’s working as expected.
As Virtualmin now supports Ubuntu 22.04 I set up a new server from scratch for testing purposes and installed the latest Virtualmin (clean install, no import of old config). However I’m noticing one major difference in its behaviour.
On Ubuntu 20.04 I was able to add a Reseller account to a Webmin group (via Webmin Users). When I do this on Ubuntu 22.04, the account stops being a Reseller account and becomes a normal Webmin user (as far as I can tell). The account disappears from Virtualmin, System Settings, Reseller Accounts, and is no longer shown when you run list-resellers.
Were you never supposed to be able to add Reseller accounts to groups in the first place, and it just “accidentally” worked on 20.04, or is there something else wrong with my config? If you’re not supposed to add Resellers to Webmin Groups, is there a better way to batch-manage available modules and settings (instead of manually per Reseller)?
SYSTEM INFORMATION | |
OS type and version | Ubuntu 20.04 / 22.04 |
Webmin version | 2.001 |
Virtualmin version | 7.2.1 Pro |
