Can anyone advise me how to add expires headers on server with Nginx? I have instructions for a regular server, but they won’t work under Virtualmin.
This is a Virualmin server running Nginx on CentOS 8.
Thanks,
Julius
Thanks,
Julius
Depends from your nginx site config
Some examples:
location /mypath/ {
expires max;
location ~* .(ico|jpg|jpeg|png|gif|svg|js|css|swf|eot|ttf|otf|woff|woff2|html|json)$ {
add_header Cache-Control “public”;
add_header X-Frame-Options “SAMEORIGIN”;
expires +1y;
Do “nginx -t” and if ok, reload or restart.
Some examples.
I will give this a try after I fix another issue. Thank you!
