Cannot see how to add the repo back. Running install.sh fails with repo not found when trying to delete the existing virtualmin repo, which of course it can’t as I already did that by accident.
Searching provides no results and docs just keep talking about clean systems and install.sh.
any help much appreciated.
Regards
BaD
You’ll find a list of the CentOS versions at this URL:
http://software.virtualmin.com/gpl/centos/
Once you determine the version you need, using something like this:
rpm -ivh http://software.virtualmin.com/gpl/centos/ [version] / [arch] /virtualmin-release-latest.noarch.rpm
For instance, if you were running CentOS 6.7, on a 64 bit machine, use:
rpm -ivh http://software.virtualmin.com/gpl/centos/6.7/x86_64/virtualmin-release-latest.noarch.rpm
or
rpm -ivh http://software.virtualmin.com/gpl/centos/7.2.1511/x86_64/virtualmin-release-latest.noarch.rpm
Be cautious.
