I have setup my Debian 9 server with the latest Virtualmin version. It’s running very well. Only I discovered two issues with chroot. I solved one (maybe needs a permanent fix for everybody in Virtualmin code). The other issue is not solved yet.
Issue 1 (solved): PHP is failing on multiple random functions. This was because ‘zoneinfo’ was missing. When I copied zoneinfo from /usr/share to my chrooted directory, it started working fine.
Example:
/home/chroot/VMINSERVERID/usr/share$ ls
perl perl5 terminfo vim zoneinfo
Issue 2 (not solved!):
PHP cannot send mails via an external SMTP server when chroot is active. It cannot create socket then.
Once I disable chroot for domain the email starts working.
Is there a way to fix this?
Thanks in advance
