Sorry to be such a pain in the butt, I need to confirm that something has not gone wrong.
Every morning I check Virtualmin for updates using the “System Information” page “Package updates”. And, of course I do update, both VM and any system updates as well.
This morning I updated to 3.74 Pro and suddenly “189 updates to system packages are available”.
That seems like quite a lot and thought I would confirm that something has not gone horribly wrong. I have not added or changed repos so am using the default as installed.
Am I relatively safe upgrading these packages ?
If so, should I just update a few at a time or just go for broke. This is scary !
Actually, the new Virtualmin version will show you packages from your distribution to update.
And CentOS just released version 5.4.
So assuming you didn’t setup a third party repository of any sort (you’d probably know if you did!), that’s completely normal, and you’re just seeing what your Linux distro vendor is providing to you.
CentOS 5.4 is a minor revision update. All versions in the “5” major revision are binary compatible. Everything that worked in 5.1, 5.2, 5.3, should continue to work unmodified in 5.4. If it doesn’t it’s a bug that the CentOS or RHEL folks would probably need to address.
That said, there wasn’t a 5.4 link in our repo until just now, so Virtualmin binary updates would have failed on a system brought up to 5.4. But that’s no big deal, and has now been fixed. It’s just a symbolic link from “5” to “5.4”
I do want to make one thing clear though, since we get this kind of question about point releases of CentOS a lot:
A .x release of CentOS or RHEL is just a re-roll of the OS to include new drivers, minor bugfixes, and new functionality (without breaking binary compatibility with all prior revisions). We support CentOS 5. Doesn’t matter what point release it is. This is why we like CentOS/RHEL on servers; it lasts a long time, gets updates regularly, and is always compatible with all prior similar releases.
Point releases of CentOS do not alter compatibility. That’s the point of CentOS and its long lifecycle (sorry for the pun).
