1 package update is available
Really - NO!
This is being displayed and still is - it will not go away.
Been there for well over 24 hrs now!
clicking on it shows nothing.
This happens every so often to me as well. Here’s the solution I’ve come up with to resolve it.
Open Terminal:
apt-get update
apt list --upgradable
apt-get upgrade
If you have something in that list you can’t upgrade because of dependencies issue?
You can do an apt-get install on that particular program so that it will install the dependencies needed.
Thanks, I had already done an upgrade but not the apt list --upgradable that showed shim signed as the culprit. Which seemed to be linked to DKIM in some way as it
